ECIDesigner Posted July 29, 2015 Share Posted July 29, 2015 Hi everyone, I am having problems changing the tile layout for a bathroom. So far I copied a tile from Daltile (StarkWhite EX01) and made a copy and pasted it into my User catalog. I successfully changed the size and changed it from "tile" to "Brick" to change the layout. I was able to change the size but the layout is giving me problems. I want a brick layout, but I can not get it to show up in my rendering as brick layout. It seems correct in the sample box photo, but it does not show up as brick layout on the floor. It is a straight run. Am I missing a step? Thanks for any advice! Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 29, 2015 Share Posted July 29, 2015 Post some image screen captures please so we can see what you mean by "layout" please. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted July 30, 2015 Share Posted July 30, 2015 What you are trying to do doesn't work well in HD as you cannot change the "Layout" of the Texture (picture) while as you have seen the Pattern file for Vector view is easily done as it is just colours. HD (and Chief) use repeating Patterns for applying the pic (texture) , so if the texture of the Tile is of a single tile as in this case HD cannot turn it into a Running Bond (brick) Layout. easiest thing to do is find a Brick Pattern (Running Bond) tile in the Library of approx. the right size and then apply the colour - EXO1 stark white to it , not the material. you could make you own brick pattern Stark White Texture file in Paint or Irfanview with the grout lines too if really needed. Link to comment Share on other sites More sharing options...
ECIDesigner Posted August 7, 2015 Author Share Posted August 7, 2015 Ok Thank you Mick! Link to comment Share on other sites More sharing options...
garyatmaui Posted July 15, 2016 Share Posted July 15, 2016 Did anyone ever find a good brick tile pattern that can be used as a templet? I am fairly new to the PRO package and have been impressed but dont understand why it can't do texture and color for brick patterns. Link to comment Share on other sites More sharing options...
LawB10 Posted July 15, 2016 Share Posted July 15, 2016 Try downloading this software from this site. www.accurateimage.com It's called Acme Brick and Masonry Designer. Link to comment Share on other sites More sharing options...
