How do I create my own title block layout lemplate to save and use with my projects
KarenHSD
I'm new to Home Designer and have the Pro version on my Mac.  I'm trying to create my own title block that I can use for all my projects.
I understand how to send to layout but I do not want to have to change the info in the title block each time. I'd like to have a personalized template that I can use.
Can someone point me to a tutorial, preferably a video that I can reference for help? I should specify that creating the actual drawing is not the problem. I think where I'm having difficulty is saving , filing and retrieving for use.
Pulling my hair out!
I've made changes to the default Plan Template so each new plan automatically has them.
I bet you can do the same with the default Layout Template. Open it, add your title block, then save.
I'm off to work, but a bit of searching here on the Forum should provide more details.
Also check the Knowledge Base for info.
