Designer_Ryan Posted November 26, 2024 Share Posted November 26, 2024 I have arches, above columns, in the dining room. Can Home Designer Pro add arches in soffits? I've found an older post (2010) stating, "you will have to use a polyline solid, or a slab. You can shape them & curve them in plan view." (How would this be done, if soffits can't be adjusted?) This is what I've drawn, with soffits. This is what I want to achieve. reference: http://www.chieftalk.com/showthread.php?49355-Curved-Soffit Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 26, 2024 Share Posted November 26, 2024 Why are you even looking at a Chief Premier help file??? AND...there is more than one way to do this. First option is to look in the Home Designer Knowledge Base. Link to comment Share on other sites More sharing options...
Designer_Ryan Posted November 26, 2024 Author Share Posted November 26, 2024 20 minutes ago, Jo_Ann said: Why are you even looking at a Chief Premier help file??? AND...there is more than one way to do this. First option is to look in the Home Designer Knowledge Base. Chief Premier came up under a google search. Thanks for giving me this, "Home Designer Knowledge Base." I saved it as a favorite. If you had a link on the words Home Designer, nothing opened. May I ask, "What did you search on the Home Designer Knowledge Base?" Link to comment Share on other sites More sharing options...
Solution solver Posted November 27, 2024 Solution Share Posted November 27, 2024 I looked at that old thread you found. It refers to a curved soffit -- a soffit against a curved wall. I also searched this forum and found a solution. Here are a couple of tips. Try to learn the tools you have available -- what they can and cannot do. Since soffits won't work, what will? Learn to think outside the box when solving a problem like this. You see soffits, I see a thick wall. Why? Because you can use the door and window tools to create arched openings in walls. You can create a Pony Wall with a Room Divider wall on the bottom, or select the wall and drag its bottom up. As for searching for help, start at the Home Designer website. the search there searches it and this forum. Search video: I don't know if this will help. I've not watched it since i made it a year ago. Link to comment Share on other sites More sharing options...
Designer_Ryan Posted November 27, 2024 Author Share Posted November 27, 2024 1 hour ago, solver said: We did it. Your video helped. I want to thank you. Link to comment Share on other sites More sharing options...
