Ginger Posted April 16, 2015 Share Posted April 16, 2015 Guys any idea how to create a Gablet roof with HD Architect, see attached pic for what I am trying to achieve. Any help would be very much appreciated, Regards from Down Under! MarkB Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 16, 2015 Share Posted April 16, 2015 This should help provided you have Home Designer Pro: DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted April 16, 2015 Share Posted April 16, 2015 In HD and Chief those Roofs are called Dutch Gables (or Dutch Hip Roof ).......use that to search the Forum or KB A post of mine from a while back on how to do it if you don't have Pro ( I think you have HDA) https://hometalk.chiefarchitect.com/index.php?/topic/182-gable-not-at-end-of-roof/#entry925 a tutorial if you do have Pro http://www.homedesignersoftware.com/support/article/KB-00749/52/Home-Designer/Roofs/Creating-a-Dutch-Hip-Roof.html Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 16, 2015 Share Posted April 16, 2015 For HD Architectural, this is similiar to Kbird's post. Use the 2nd floor blank option to draw these walls. You will probably have to play with all the settings, including the wall placement, to make it behave in your own plan. At least, it should help to get you started in the right direction. Attached Thumbnails 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 16, 2015 Share Posted April 16, 2015 Found the old Plan ,so you can look at it to if needed, there are notes on the plan which should help. The main Roof is a Gullwing ,so you may not need those settings. Dutch Gable without Pro Roof planes_2.plan Link to comment Share on other sites More sharing options...
Ginger Posted April 17, 2015 Author Share Posted April 17, 2015 A big "thanks" guys..! From down under So easy... awesome!! Link to comment Share on other sites More sharing options...
