Designer_Ryan Posted 9 hours ago Share Posted 9 hours ago After extending walls to existing walls I have to select the longer wall, press the number 3 to break the wall, then I have to delete the longer portion of the wall. Is there a shortcut to this, instead of having to do three steps? Here's an example. On the bottom left of this garage the wall extends. Link to comment Share on other sites More sharing options...
Rookie65 Posted 9 hours ago Share Posted 9 hours ago Why don't you just click the wall and drag the left wall back to the vertical wall? Link to comment Share on other sites More sharing options...
solver Posted 9 hours ago Share Posted 9 hours ago I'm using Pro 2024, not 2023 as I said in the video. Link to comment Share on other sites More sharing options...
Designer_Ryan Posted 9 hours ago Author Share Posted 9 hours ago Thanks to both of you. I'll work with both your ideas. Link to comment Share on other sites More sharing options...
