SavvyConstructor Posted August 30, 2024 Share Posted August 30, 2024 I have set my roof overhang to 8" Eaves and 9" Gable. Why is it when I rebuild the roof, the eave overhang is flush to the wall? When I open the roof plane, it is telling me that the overhang from baseline is 3/16" but I'm not able to edit that number. Screenshots attached Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 30, 2024 Share Posted August 30, 2024 I am guessing from your image that most likely you manually drew the problem roof plan misplacing its "Base Line" from the outer edge of the bearing wall to a more inward position. Overhangs are computed from the baseline, just a guess. Are you using Home Designer Pro? If you were to share a copy of your problem plan I could be more certain in response. DJP Link to comment Share on other sites More sharing options...
SavvyConstructor Posted August 30, 2024 Author Share Posted August 30, 2024 Yes I'm using home designer pro. I'll attach the plan below. Nussbaum Screened Porch.planFetching info... Link to comment Share on other sites More sharing options...
solver Posted August 30, 2024 Share Posted August 30, 2024 Always say what product you are using. Pro 2020, Pro 2024 etc. I opened your plan and this is what I see. Why are you not auto building the roof? Link to comment Share on other sites More sharing options...
SavvyConstructor Posted August 31, 2024 Author Share Posted August 31, 2024 I'm using Home Designer Pro 2024. I had to manually edit the framing on the existing structure (house) because after I manually edited the roof plane to get the gable wall truss to generate against the house, the framing was not the way I wanted it. So I was prompted to turn off auto roof builds. I'm trying to figure out why the overhang is not correct when I adjust it to 8"eaves and 9" gable. If you go into the plan and adjust the overhang to any number, then rebuild the roof, it will set the overhang to flush. Link to comment Share on other sites More sharing options...
SavvyConstructor Posted August 31, 2024 Author Share Posted August 31, 2024 From the looks of it, the baselines are placed at the outer edge of the bearing wall. Link to comment Share on other sites More sharing options...
solver Posted August 31, 2024 Share Posted August 31, 2024 Try changing your default pitch. It's set to 1/4". Generally, when you have a roof with multiple pitches, set your default to the most common one, then change the pitch in the wall spec as needed. Link to comment Share on other sites More sharing options...
SavvyConstructor Posted August 31, 2024 Author Share Posted August 31, 2024 Okay that seemed to work to fix the overhang but when the roofs got rebuilt, the walls on the porch lowered and got all messed up. How do I fix this part? Link to comment Share on other sites More sharing options...
solver Posted September 1, 2024 Share Posted September 1, 2024 On 8/31/2024 at 6:13 PM, SavvyConstructor said: How do I fix this part? Expand https://youtu.be/8MOiqXgGR2A 1 Link to comment Share on other sites More sharing options...
SavvyConstructor Posted September 1, 2024 Author Share Posted September 1, 2024 Hi Eric, Thanks for the video. That was very insightful. I've created a video to show you some of the issues I've run into after following the process you laid out. Here's a link to the video. I'll attach the current state of my plan below. Nussbaum Screened Porch.plan Nussbaum Screened Porch.planFetching info... Link to comment Share on other sites More sharing options...
