JayWebb Posted August 3, 2024 Share Posted August 3, 2024 I have been trying all day to create an elevation in my terrain, and have tried everything. The image shows the red line where I need the terrain to slop up to the second level of the house. I have tried terrain elevation lines and all I get are too many slops throughout the whole damn terrain! Please, can someone PLEASE help me to create a simple slope where the back of the terrain stays the same? Thanks in advance. mmaster.mat Link to comment Share on other sites More sharing options...
Rookie65 Posted August 3, 2024 Share Posted August 3, 2024 Set a bunch of elevation lines for the low height and call them "0". Then a bunch for the higher elevation. (+ how much the difference should be). Keep a space between the high and low for the distance you want to have sloped. Rebuild terrain and it should take care of it. The reasons for having a bunch at the same elevation on each side is to keep those areas flat. It's not too hard once you get an understanding of how it's programmed to work. 1 Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 3, 2024 Share Posted August 3, 2024 1 Link to comment Share on other sites More sharing options...
JayWebb Posted August 4, 2024 Author Share Posted August 4, 2024 5 hours ago, Rookie65 said: Set a bunch of elevation lines for the low height and call them "0". Then a bunch for the higher elevation. (+ how much the difference should be). Thanks; I've been fooling with it now for hours and I think I've finally got it to where it's acceptable. It isn't exact, but at least now I can place driveway and flower beds, and sidewalks. Link to comment Share on other sites More sharing options...
JayWebb Posted August 4, 2024 Author Share Posted August 4, 2024 Thanks. I worked with it for hours and have come up with an acceptable look. Not exactly what I needed but it works lol I will try your elevation region idea and see if that works out. Thank you so much. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 5, 2024 Share Posted August 5, 2024 20 hours ago, JayWebb said: Thanks. I worked with it for hours and have come up with an acceptable look. Not exactly what I needed but it works lol I will try your elevation region idea and see if that works out. Thank you so much. you might try posting your plan file. you posted a material file Link to comment Share on other sites More sharing options...
