WarwickB Posted July 21, 2024 Share Posted July 21, 2024 How do i get my building back to earth, its floating above the surrounding land, Just new to this. Link to comment Share on other sites More sharing options...
y-g-m-n Posted July 21, 2024 Share Posted July 21, 2024 can you upload plan file? Have you messed with terrain? Link to comment Share on other sites More sharing options...
WarwickB Posted July 22, 2024 Author Share Posted July 22, 2024 Untitled 1.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 22, 2024 Share Posted July 22, 2024 Terrain was added as a feature to this software in 2,000 AD and has always been treated as an "add on". The terrain has a dialog box and part of that dialog box is an input box called "Building Pad". This input box controls the overall height of the terrain plane as an object relative to the "Zero Inches of the first floor's surface". Using trial and error changing the input box values will raise or lower the terrain relative to the structure's height. Take a look and practice with that dialog box-input box. DJP Link to comment Share on other sites More sharing options...
Garybills Posted August 8, 2024 Share Posted August 8, 2024 @WarwickB I don't know if you figured it out yet, but your plan is built on the second floor, and you have a blank 1st floor. Delete the black first floor and rebuild the terrain. Link to comment Share on other sites More sharing options...
