Mav2294 Posted May 3, 2024 Share Posted May 3, 2024 I'm using Home Designer Pro 2024 on Windows (recently upgraded from 2015 so I'm still learning some of the new features). I have a single story home with a walk-out basement. On the foundation level, there is a patio. On the 1st floor, there is a covered porch and adjacent uncovered deck, both of them above the lower patio and supported on wood posts/columns. My question is what room type should I use for the covered porch? The framing is similar to a deck, but the room materials, floor covering, roof, walls and other features are more similar to a typical porch. Importantly there is no foundation below the porch as it is supported on wood columns. I need to have control over where the columns are placed and how the underside of the covered porch is framed. Thoughts? Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 4, 2024 Share Posted May 4, 2024 how is it coveered? Using HOUSe ROOF or a separate roof with differeent material and pitch.. Example house is 12:!2 pitch with architectural shingles. Covered porch is aluminum stuff from the gutter guy.. IF same and part of house roof just make it a deck Click on room edit button for it and I think go to structure tab. Then check ROOF over this room. IF different just make a custom roof plane and set it up to your liking Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 4, 2024 Share Posted May 4, 2024 y-g-m-n ????????????? Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 4, 2024 Share Posted May 4, 2024 mav2294, Your question is very vague. Not enough info on what you want, and what you currently have. Link to comment Share on other sites More sharing options...
Mav2294 Posted May 4, 2024 Author Share Posted May 4, 2024 The roof is the same roof as the house. The question is what room type should I use for the covered porch. The framing is similar to a deck, but the interior is similar to an interior room (solid floor, not deck boards, walls with windows all around). If I set the room type to Porch or a different type of interior room, then HDP frames it like a regular room which isn't what I need - I need the under side framed similar to a deck and supported on wood posts/columns, not on a foundation. If I set it to a deck, then I can get the floor framing I need, but the floor itself is wood deck boards (not a solid floor) and getting the walls to be solid instead of a railing has been troublesome. Hope that clarifies the issue. Thanks - Mav. Link to comment Share on other sites More sharing options...
Rookie65 Posted May 4, 2024 Share Posted May 4, 2024 Use a room and manually add the posts you want with auto build foundation turned off Link to comment Share on other sites More sharing options...
Mav2294 Posted May 4, 2024 Author Share Posted May 4, 2024 I'll try it that way, thanks. Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 5, 2024 Share Posted May 5, 2024 Hey I was just guessing as I did not and still confused on what he wants. I am sure it is something simple.. Oh well I need more coffee Link to comment Share on other sites More sharing options...
