twiseva Posted March 10, 2024 Share Posted March 10, 2024 Hi all, new to architect but could not find much around newels and my current challenge of an 'embedded' Newel. I have an internal railing around a 'open below' section and the 'newels' are turned on. I cannot seem to figure out how to stop the end Newel being embedded into the wall it attaches to. Actually, it'd be nice to be able to place newels only where I want them in the railing but ... just addressing this would be good enough. I am using Home Designer Architectural 2024. Link to comment Share on other sites More sharing options...
Solution solver Posted March 10, 2024 Solution Share Posted March 10, 2024 You can set your newels to a 0" width, then place them manually (choose from library). To force a full newel against a wall, pull the railing back from the wall, draw a Room Divider wall perpendicular to the railing, then another Room Divider from it to the wall forming a T. Select the perpendicular Room Divider and move it close to the wall -- maybe 1/16" away. Then drag the railing wall letting it snap to the perpendicular Room Divider. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 10, 2024 Share Posted March 10, 2024 Open the railing and set the newel location at the end or start of the wall depending on the location. Change the newel from half to none Link to comment Share on other sites More sharing options...
solver Posted March 10, 2024 Share Posted March 10, 2024 On 3/10/2024 at 11:25 PM, Rookie65 said: Open the railing and set the newel location at the end or start of the wall depending on the location. Change the newel from half to none Expand Only in Pro, not an option in Architectural or Suite. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 10, 2024 Share Posted March 10, 2024 That's too bad. Might be worth an upgrade then as other shortcomings are discovered Link to comment Share on other sites More sharing options...
twiseva Posted March 11, 2024 Author Share Posted March 11, 2024 On 3/10/2024 at 11:24 PM, solver said: You can set your newels to a 0" width, then place them manually (choose from library). To force a full newel against a wall, pull the railing back from the wall, draw a Room Divider wall perpendicular to the railing, then another Room Divider from it to the wall forming a T. Select the perpendicular Room Divider and move it close to the wall -- maybe 1/16" away. Then drag the railing wall letting it snap to the perpendicular Room Divider. On 3/10/2024 at 11:52 PM, Rookie65 said: That's too bad. Might be worth an upgrade then as other shortcomings are discovered Expand Expand Thanks @solv and @Rookie65 for such quick response. The invisible wall trick I could see being helpful in several situations! Yeah, it's a big jump of $$ BUT I'll keep track and then maybe ... A long way to go yet (I am recreating our current house so I can experiment with designs, paints, and garden designs). Link to comment Share on other sites More sharing options...
