Stair railings
SandraH
Go to solution Solved by solver,
I need to customize railings for "U" shaped stairs.
I need to put railings on upper staircase on inside to post on the landing, and on the lower level on outside.  Is there a way to do this?
Is it possible to have the stairs unconnected?
  • Solution
1 hour ago, SandraH said:
I would like them to not have the railing at the wall at the lower portion.
Hold Control (or Command) and click the lower section to select only it.
Open it and change the railing.
