DaveCampbell Posted June 5, 2023 Share Posted June 5, 2023 have spent way more time than i thought i would with a $100+ tool, trying to simply draw up my existing house in order to start thinking / drawing up renovation plans. anyway, i have 2 rooms (a garage and a sunroom) that seem to have lost their floors. these are on 'slabs' as that seemed the only way i could reasonably control the floor heights, which is about 12" below the regular house - and actually are on slabs. i fiddled with the foundations and the stem walls, etc., etc. for hours - just to get the floor offsets to look even close to reality. so is there is some basic sanity check i can perform to explain why i have lost the floors on these 2 rooms? the floor materials show as concrete and terra cotta, respectively, but i see nothing but blue-sky in the 3D view. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 5, 2023 Share Posted June 5, 2023 In the "Room Specification Dialog box-Structure Tab-Floor Finish is probably marked "zero inches". That is could be causing there to be no visible floor. Another possible cause is in checking the "Room Specification Dialog box-Structure Tab-Floor Structure-Floor Supplied by floor below", such selected choices can cause there to be no visible floor. Take a careful look, please. DJP Link to comment Share on other sites More sharing options...
DaveCampbell Posted June 9, 2023 Author Share Posted June 9, 2023 thanks for your reply. floor finish is set to 7/8", which i think is a default. i would not have ever changed anything like that. and the second option doesn't appear to be available on my version (Mac). i'm sure all the dependencies at play in the software is subtly involved - and those dependencies are what is driving me CRAZY. between foundations and Stem Wall Tops,and about 30 other aspects that change and affect all the other pieces - i'm really finding this tool to be just too much. and don't get me started on roofs. these 2 rooms were added to the house and one has a simple shed roof, the other a hip roof, but one angle must match a shed like roof that merges into the roof overhang on a front porch. i've spent probably 4 hours this week on JUST that - and the roof looks like a Frankenstein. at some point there needs to be a simple option where you just drag the hip where it needs to be, or raise one side of a shed roof with a simple arrow. and all i'm trying to do is draw my existing house in order to run through some design ideas for an expansion. i can't even get the existing house drawn up. but thanks again for your suggestions. Link to comment Share on other sites More sharing options...
Garybills Posted June 9, 2023 Share Posted June 9, 2023 Can you post your plan and maybe someone can figure out what’s going on. I tried to replicate your situation but wasn’t able to. Also, what version of Home Designer are you using? Link to comment Share on other sites More sharing options...
DaveCampbell Posted June 9, 2023 Author Share Posted June 9, 2023 Yeah, sure. Don't go too far out of your way - there's probably a lot of things I am doing wrong compared to folks using this tool for their everyday work. As an engineer (EE), and even some AutoCAD experience many decades ago, I thought this task would be easier than it has turned out to be. I even upgraded to a new Mac in order to mess with this thing. I think the Mac version of Home Designer may have issues - lots of features I see in the docs that aren't on my version, and it does crash every so often. Notes on the house, if it matters: The garage and 'sunroom' are on a slab, which is like 12" below the floor level of level 1. The roofs on those are challenging, to say the least. No idea why I'm spending so much to get the existing right - those are the parts of the house we are hoping to tear out. But I want to see if this is easier than what I am making it. AS-IS.plan Link to comment Share on other sites More sharing options...
Garybills Posted June 9, 2023 Share Posted June 9, 2023 I only have the trial version of Suite 2023, so I tried to make some notes to help you out. It's a matter of setting up the walls for the roof, especially the back sunroom for the upper pitch. I built the foundation, and the garage and sunroom floors came back. I hope this gets you on the right track. 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted June 9, 2023 Share Posted June 9, 2023 Try checking "floor under this room" in the structure tab Link to comment Share on other sites More sharing options...
DaveCampbell Posted June 13, 2023 Author Share Posted June 13, 2023 @Garybills - thank you SO much for those efforts and details. i will get to work to run through each of those walls. i don't think i have a firm understanding of how real roofs actually work or are designed and constructed so i found that level of detail quite overwhelming. and the floor was somehow related to the foundation - another detailed area i kind of threw my hands up on. you have a great handle on this tool - i'm sure your customers get some awesome designs. i am finding using a 'professional' design tool a bit of an uphill climb, but the 3D results will be very much worth it as we start to work through how we'd like to make some changes. hopefully, that effort will be useful as we start to engage designers and contractors about what we're thinking about and then work back to what is possible and affordable. thanks again for your efforts. i hadn't been on this since last week - have to partition my attention a fair amount to keep from going down rabbit-hole after rabbit-hole - a techno-junkie's dilemma! Link to comment Share on other sites More sharing options...
DaveCampbell Posted June 13, 2023 Author Share Posted June 13, 2023 Thanks for the idea @Rookie65 - the floor issue definitely has something to do with either the foundation or the floor below. Link to comment Share on other sites More sharing options...
Maven1x Posted July 5, 2024 Share Posted July 5, 2024 I remember a similar issue when I was redoing my living room. Turned out, I had accidentally hidden a layer in my design software. Maybe it's something simple like that for you too? One thing that helped me was checking all my layer settings and making sure nothing got hidden by mistake. Also, are the floors visible in the 3D view but missing in the plan view? That could give you a clue. By the way, if you're ever thinking about adding more light to your space, you should check out these amazing sunrooms: https://www.scottsofthrapston.co.uk/sunrooms/. They might inspire you for your next project! Link to comment Share on other sites More sharing options...
