Opening indicators will not reverse to handle side ?
JosephLombardo
Go to solution Solved by Rookie65,
  • Solution
You have it checked in Legacy plan file. Go to your plan's default settings under "Plan" and look for the box near the bottom. That is where it should change for you. Double doors may be the exception to the rule, unless you mark it center hinged maybe?
Expand
Hi Rookie65 that is the solution. Tech support got back to me.
Screen Recording 2023-05-04 at 9.49.59 am.mov
