Interior door, different colour either side?
Kristine
Quick question, I can't see a way to change the colour of an interior door from one side to another (and its casing too for that matter)? I know this can easily be achieved with exterior doors, but what about interior doors? Is this possible or is there a workaround? Thank you.
Open the door specification box, and under options, check "separate trim and materials on each side". Change the exterior to match the interior casing if needed. Then you can paint the door, trim and casing for the desired side. I don't believe you can set an interior door as an exterior, as the door defaults by the wall type it's put into..
yes I forgot about that check box was the way to do it.
Been a while since I messed with Doors as I jusgt set my default an go withit.
