Cabinets
Fredo649
Go to solution Solved by DavidJPotter,
If the cabinets are solid doors, try putting 2 - 6" deep ones back to back. If the doors are glass, then maybe an "open front and back" block with glass doors at each end? Try some creativity when things are not readily available as you'd like.
  • Solution
I also looked in X14 and X15 to see if this functionality is possible, it was not in Pro or Premier.
But what you can do is to create your cabinets and then create a one inch thick cabinet of what ever type so it emulates  a door or doors, that you can then locate on the back of cabinets as a work round to get that look you wish. It may be possible to do this in Pro and Premier but I could not find it if it exists as a function.
Expand
Yes that is what I am doing , Thanks.
