Fredo649 Posted February 27, 2023 Share Posted February 27, 2023 I have been looking to see if it is possible to place doors on both sides of upper cabinets for a peninsula but I have not seen a way to do that. Is there a way or not in HDPro. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 27, 2023 Share Posted February 27, 2023 DJP Link to comment Share on other sites More sharing options...
Rookie65 Posted February 27, 2023 Share Posted February 27, 2023 David, He wants to put doors on both sides of a wall cabinet that is going over peninsula or island cabinets. Not against a wall, it will be in the middle of the room. Link to comment Share on other sites More sharing options...
Fredo649 Posted February 27, 2023 Author Share Posted February 27, 2023 18 minutes ago, Rookie65 said: David, He wants to put doors on both sides of a wall cabinet that is going over peninsula or island cabinets. Not against a wall, it will be in the middle of the room. That is correct Rookie65. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 27, 2023 Share Posted February 27, 2023 If the cabinets are solid doors, try putting 2 - 6" deep ones back to back. If the doors are glass, then maybe an "open front and back" block with glass doors at each end? Try some creativity when things are not readily available as you'd like. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted February 27, 2023 Solution Share Posted February 27, 2023 I also looked in X14 and X15 to see if this functionality is possible, it was not in Pro or Premier. But what you can do is to create your cabinets and then create a one inch thick cabinet of what ever type so it emulates a door or doors, that you can then locate on the back of cabinets as a work round to get that look you wish. It may be possible to do this in Pro and Premier but I could not find it if it exists as a function. DJP Link to comment Share on other sites More sharing options...
Fredo649 Posted February 27, 2023 Author Share Posted February 27, 2023 50 minutes ago, DavidJPotter said: I also looked in X14 and X15 to see if this functionality is possible, it was not in Pro or Premier. But what you can do is to create your cabinets and then create a one inch thick cabinet of what ever type so it emulates a door or doors, that you can then locate on the back of cabinets as a work round to get that look you wish. It may be possible to do this in Pro and Premier but I could not find it if it exists as a function. DJP Yes that is what I am doing , Thanks. 1 Link to comment Share on other sites More sharing options...
