kitmuu Posted March 20, 2015 Share Posted March 20, 2015 I am using HD Suite 2012 and am trying to create a loft on the 3rd floor (to be open to the 2nd floor below). Following the instructions in the FAQ tutorial on creating a loft results in a floor plan that says "Open Below" in the right place, but there is still a floor there in the 3D camera view. I cannot figure out what I am doing wrong, but I suspect maybe something related to how I created the roof. I tried using an invisible wall as well as a railing to create the separate room that could be given the "Open Below" designation, but neither way has worked. Thanks for your help. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 20, 2015 Share Posted March 20, 2015 Post a copy of your plan please. I looks like you have the ceiling height set too low in the Loft area (the railing looks flat as a pancake), but without the plan file I can only guess. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted March 20, 2015 Share Posted March 20, 2015 Did you previously add anything extra to the second floor at that end? , those are ceiling joists showing not floor joists for some reason. as DJP said , post the plan its the easiest way.... M. Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 20, 2015 Share Posted March 20, 2015 I suspect that you built the 3rd floor with the ceiling set to '0', then you spray painted the osb 'ceiling' with tongue and groove siding? You need to open the dialog box for each room, and uncheck 'ceiling over this room'. You should then be able to see the floor 'below', and the framing structure will also change. Link to comment Share on other sites More sharing options...
kitmuu Posted March 20, 2015 Author Share Posted March 20, 2015 Thank you for the help; you are correct that the ceiling height was set extremely low (leftover from a previous failed attempt to get the roof to work). Adjusting that to the right height fixed the problem. Thanks again! Link to comment Share on other sites More sharing options...
Kbird1 Posted March 21, 2015 Share Posted March 21, 2015 interesting , nice catch Jo_Ann , I would not of guessed that a low ceiling height would effect the Open Below Setting somehow... Link to comment Share on other sites More sharing options...
