JoeJC1 Posted September 16, 2022 Share Posted September 16, 2022 Hello, I have a landscape and I put landings to create the irregularly shaped concrete steps. However the landings when connected together create these "sides" that I cannot figure how to get rid of them (see first picture). Then when trouble shooting, I raise one of the landings higher than where I want it and it makes the sides go away. (see 2nd picture). I attached the file also if that helps. Please help if you can. Thank you. Link to comment Share on other sites More sharing options...
solver Posted September 16, 2022 Share Posted September 16, 2022 2 hours ago, JoeJC1 said: I attached the file also if that helps. Nothing attached. A couple of tips on images for posting here. Use Vector View unless you need to show Textures. Use these settings: And experiment with the other camera settings, especially Ambient Occlusion . Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 16, 2022 Share Posted September 16, 2022 I recommend you use custom slabs instead of landing objects, they are easier to customize than landings, that is if you do not require railings which come with Landings and do not come with Custom Slabs. DJP Link to comment Share on other sites More sharing options...
JoeJC1 Posted September 17, 2022 Author Share Posted September 17, 2022 Thank you for the replies. Here is the file attached. Eric, I understand what you referring to with the shade in the picture. Thank you for pointing that out. David, on using custom slabs, i found your youtube video on creating custom slabs, thank you. That should work if I have to change them all. I will change all of the landings to slabs if it is the only way, but I am curious to know if someone sees an error in what I did in the file for only some to show as the "side" and others not. Thank you, Joe for HD forum review.plan Link to comment Share on other sites More sharing options...
