ScotMoore Posted September 6, 2022 Share Posted September 6, 2022 Is there a way to have the roof to be built with Trusses. After getting the roof lines to align properly the roof is not building with trusses but rather building as a stick built. How do you tell the program to build with trusses? Thanks Link to comment Share on other sites More sharing options...
solver Posted September 6, 2022 Share Posted September 6, 2022 Suite doesn't do trusses. Link to comment Share on other sites More sharing options...
ScotMoore Posted September 6, 2022 Author Share Posted September 6, 2022 2 minutes ago, solver said: Suite doesn't do trusses. Thanks, that was what i was afraid of. I assume Pro will allow to build with trusses? Do you know if Pro allows you to change the truss type in the lower level floor? Scot Link to comment Share on other sites More sharing options...
solver Posted September 6, 2022 Share Posted September 6, 2022 8 minutes ago, ScotMoore said: I assume Pro will allow to build with trusses? Yes 8 minutes ago, ScotMoore said: Do you know if Pro allows you to change the truss type in the lower level floor? Truss type? Keep in mind that trusses are designed by an engineer and accurate depiction is left up to them. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 7, 2022 Share Posted September 7, 2022 That Pro builds virtual trusses, it is not a State Licensed Structural Engineer or Lumber Company. Only those sources can legally design trusses. Home Designer Pro and Chief Architect Premier can draw manually, trusses but as I said they are Not legal to submit for permits, only State licensed persons can design trusses. DJP Link to comment Share on other sites More sharing options...
