Soffit Trim at Rakes & Eaves?
philiplaird
Thanks for your reply.
The "Custom Backsplash" tool creates a polygon and uses the polygon control settings. I find it easier to use the "Soffit" tool as it uses Size/Position control settings which make it easier to size and place accurately. Soffits can also be replicated using the "Transform/Replicate Object" dialog making it easy to copy and place on other walls.
I was just wondering if I missed something in the 2023 upgrade. It seems like this would be something used frequently when rendering house plans. You can "Auto Place" corner boards, but not soffit trim or brick frieze!
