Designer_Ryan Posted June 12, 2022 Share Posted June 12, 2022 I'm trying to add different wall heights in the same room. Where the fridge and pantry is, the wall height is 8'-1/4", and the wall to the left of the fridge is 10'. The only way that I have found wall heights can be adjusted is use a half wall. Can I not add bi-fold doors in half walls? I wasn't able to add some types of doors. A door type that can be added the opening goes all the way up. 1- How can I adjust a new wall that is created to a specific height, so I can add a bi-fold door, to the right of the fridge? 2- In a half wall, what is the trim that's on the ceiling height. above the short wall? Can it be moved down to make a flat, drywall closure? 3- Why can't a regular sizes interior wall be right next to a half wall without being cut at the top? Link to comment Share on other sites More sharing options...
Jo_Ann Posted June 12, 2022 Share Posted June 12, 2022 Poor,confusing explanation of what you want it to look like. So, I am guessing. Is this what you want? Link to comment Share on other sites More sharing options...
Designer_Ryan Posted June 12, 2022 Author Share Posted June 12, 2022 Sorry for the confusion. You got it very close. Here's a picture of the kitchen. It has more an "open" view at the top. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted June 12, 2022 Solution Share Posted June 12, 2022 Such specialized conditions take additional manual adjusting of wall polylines and specialized settings (Shelf Ceiling) to achieve. DJP Link to comment Share on other sites More sharing options...
Designer_Ryan Posted June 13, 2022 Author Share Posted June 13, 2022 1 hour ago, DavidJPotter said: Such specialized conditions take additional manual adjusting of wall polylines and specialized settings (Shelf Ceiling) to achieve. DJP DJP, Thanks for mentioning one phrase, "Shelf Ceiling." I did a search and accomplished the lower wall in front of the higher wall. 1 Link to comment Share on other sites More sharing options...
