chimney build
AlanS7
Go to solution Solved by solver,
How can i build a chimney in home designer pro 2022?
I would like it to have stone on both sides of the wall.
Can someone direct me to a youtube tutorial.
The only tut I can find is for premiere, and Pro doesn't have those features in the menu.
This is as far as I have gotten.
I used a bump out wall. sometimes it puts a roof over it at the 8 foot level. I'm not sure why this one goes to the roof. I want it to go thru the roof. the fireplace doesn't insert all the way.
Then you created a room that you can control the height of.
Walls will build up to a roof automatically -- that's why you have attic walls.
The simplest way is to use a solid like a slab and make it as tall as needed.
