Lost all menus/submenus in HDP - how do I get default settings back?
Wayn_CA
Folks, the title pretty much says it all... I was working with HDP this afternoon, and did a screen capture which I pasted into Paint.  I went back to HDP and the image was now in B+W and all my menus except "File Edit Tools Help" had disappeared... how do I fix this?
17 hours ago, solver said:
Did you reboot?
Yes, I rebooted...
6 hours ago, DavidJPotter said:
Also toolbars can be turned on  or off under the "View" main menu "View - Toolbars", you may have accidently turned them  off but you can either reboot or just turn them back  on under the View Menu.
This is what my HDP screen looks like...
4 hours ago, solver said:
Also check this setting if you are not seeing the startup screen.
That didn't do it... but while in Preferences I clicked on 'Reset Options' and basically reset everything... now the only issue I have - that I know of - is that my drawing is in B+W instead of color, per below image.  Any takers on how to get back to color?  I know most of you know.
