NorseMN Posted January 6, 2022 Share Posted January 6, 2022 Fortunately, I started my day by saving under a new name. I made only s few changes, and suddenly I can't properly select rooms on the second floor. There's one large bedroom that can't be selected at all, and all other rooms are selected together plus a border outside the exterior walls of the house. Image attached. OOPS! CORRECTION: I opened my version from yesterday and found that the problem started there. That's several hours or work difference from the previous day, which id OK. I know that I have a pretty old software version (2011). My upgrade options expired long ago. Would it be worthwhile to just buy a new version? Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted January 6, 2022 Solution Share Posted January 6, 2022 Look for, find and correct either a wall that is programmed to be "No Room Define" in its dialog box or a wall connection that is not properly connected to solve this situation. You can try the "Fix Wall Connections" command found under the "build - wall+ dropdown menu. DJP Link to comment Share on other sites More sharing options...
NorseMN Posted January 6, 2022 Author Share Posted January 6, 2022 I was finally able to access the 2nd floor bedroom properties in the 3D view and found that the floor had dropped to the first floor level. Once I got that fixed, things started working better. I still had access other rooms in the 3D view to fix ceiling heights to default. When I made each change, I got warnings about negative ceiling heights and a room would be selected in 2D, but I couldn't do anything other than click away the messages. When the last error message was gone, so was the selection. I was back to being unable to select the faulty room. Fortunately, I could get at it in the 3D view. Now I'm on to new problems. Thanks much for your suggestion, I'll mark this as solved. Link to comment Share on other sites More sharing options...
