Can't revert to default cabinet materials
4ndrew
I have defaults set up & working for cabinets if I add a new cabinet.
However, if I try to restore defaults to an existing cabinet, it only works on some of the materials.
I remember there being some odd conflict between "defaults" somewhere, but I believe I have everything set properly.
You can see in this image that defaults are set to "Color - Light" for pretty much everything, but the cabinets are showing two materials.
Further, when I change defaults, I don't see it reflected in all cabinets of the same type.
How can I actually set & restore to material defaults?
thanks
1 hour ago, solver said:
Not all defaults are dynamic, and this applies to all objects, not just cabinets.
You will need to manually reset some things.
Hi Eric - yeah, been through that process; at least, in some cases, selecting multiple components of a cabinet when the dialog is opened allows the user to set them simultaneously.
Still, really clunky.
