LeekyBoatStudio Posted December 1, 2021 Share Posted December 1, 2021 Hi guys! I have been struggling for hours and don't know if what I want is possible. I do not have pictures because it is something I thought up myself so I will try to explain well. Also, a reminder I am on HDS Pro 2021. Alright. I am working on a small structure less than 600 square feet. The building is basically split in half with a bedroom, bathroom and mechanical room on one side and an open living kitchen on the other. The building has a shed roof with a 4 pitch. I and doing a flat ceiling on the bedroom side and a sloped ceiling on the kitchen side. This all works fine. Now for the problem... I want to create a large storage space in the attic space over the bedroom side with small access doors from the kitchen side. When I try to make that space usable it tells me I can't do it because it is an attic space with auto generated walls. I have tried making it a 2nd floor so it is usable but then it still adds the auto walls to make the shed in the attic again and I have a 2 story house with an attic space I can't use. So, basically I want the angled space created over the flat ceiling by the shed roof to have a floor and be a usable room. Let me know if this doesn't' make sense. Any advice is appreciated. Thank you! Ashley Link to comment Share on other sites More sharing options...
solver Posted December 1, 2021 Share Posted December 1, 2021 You can only define rooms on numbered floors. Don't understand the problem with auto walls. Maybe a picture or two? Link to comment Share on other sites More sharing options...
LeekyBoatStudio Posted December 1, 2021 Author Share Posted December 1, 2021 So I rebuilt and took pictures. This is the exterior of the shell and it looks how I want. This is the interior kitchen side showing the sloped roof with the 2 doors leading in to the space above the flat ceiling of the other rooms and below the sloped roof. This looks good, just have to add trim below doors. This is what the inside of that space looks like. This is the problem. I want it to look finished. All the walls seen are auto generated and I can't make it a room because it is in the attic. 1st floor plan Attic with Auto Generated walls. Everything is good except the way the room looks. I have tried everything I can think of to make it a real room. Hope this clarifies a bit... Link to comment Share on other sites More sharing options...
LeekyBoatStudio Posted December 1, 2021 Author Share Posted December 1, 2021 So, I guess the goal is to have a fully functioning room in the space above the flat ceiling and below the roof slope on that side of the house. Link to comment Share on other sites More sharing options...
solver Posted December 1, 2021 Share Posted December 1, 2021 On 12/1/2021 at 1:20 AM, LeekyBoatStudio said: and I can't make it a room because it is in the attic. Expand On 12/1/2021 at 12:33 AM, solver said: You can only define rooms on numbered floors. Expand Link to comment Share on other sites More sharing options...
LeekyBoatStudio Posted December 1, 2021 Author Share Posted December 1, 2021 I understand that. What I don't understand is how to create that room in any way. When I try to create it as a 2nd floor it creates a full sized room and the program then adds those same automatic walls on the attic floor. So it is not creating a room in the space above the ceiling and below the slope, but is creating a whole room and shifting up the space above the ceiling and below the slope. I guess the big question is, is it possible to create a finished space where I want it? Can a short room be created above one flat ceiling and directly blow the slope of the roof? Link to comment Share on other sites More sharing options...
solver Posted December 1, 2021 Share Posted December 1, 2021 1 Link to comment Share on other sites More sharing options...
LeekyBoatStudio Posted December 1, 2021 Author Share Posted December 1, 2021 Thank you! That is perfect. The thing I was missing was the ignore the top floor check box. I did everything else exactly how you were doing it except that. Thank you again for taking the time to help and make the video. I knew there had to be a way! Link to comment Share on other sites More sharing options...
