CCarpenter Posted September 16, 2021 Share Posted September 16, 2021 Yikes I've got a mess! I have a couple things going on. I'm working on modeling an existing house for a renovation. I've attached photos of the house. The grade slopes so one enters the house on the 1st floor and goes down to the lower floor. Also as you can see from the photo labeled - Entry, the garage is higher than the 1st floor elevation and I've been trying to model that correctly. I've modeled the 1st floor and thought if I followed the video for the walkout basement I could change the basement walls as required to exterior walls and then create a new foundation under. Is this the best way to go about it? Also, in the walkout video, the height of flat regions are able to be specified but, I don't seem to be able to do that. Does Pro not have that capability? Am I missing something? Thanks for your help! Boyd Existing.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 16, 2021 Share Posted September 16, 2021 Click on this link and then study the "Help Articles and videos offered". DJP Link to comment Share on other sites More sharing options...
CCarpenter Posted September 16, 2021 Author Share Posted September 16, 2021 Ok, thanks for the link -helpful. What about the ability to assign a flat region an elevation? Thank you! Link to comment Share on other sites More sharing options...
CCarpenter Posted September 16, 2021 Author Share Posted September 16, 2021 BTW I had already watched that video you sent the link to several times and I mentioned that in my question. So, I retract, this wasn't helpful Link to comment Share on other sites More sharing options...
Jo_Ann Posted September 16, 2021 Share Posted September 16, 2021 "Yikes I've got a mess!" is an understatement. You have so many things to fix, with BOTH the house and terrain, that I wouldn't even know where to begin. But as for setting a height for a "region", take a closer look at the terrain tools. You have an elevation region and a flat region. Which tool do you think that you should use if you want to specify a height? Link to comment Share on other sites More sharing options...
CCarpenter Posted September 17, 2021 Author Share Posted September 17, 2021 Actually, I figured it out i.e.: how to create the lower level, fix the garage level and roof. I've fixed most of the issues. But, thanks for commenting. Regarding the terrain, I was using a flat region not an elevation region and that is why I couldn't adjust the elevation. Link to comment Share on other sites More sharing options...
