SandraH Posted August 30, 2021 Share Posted August 30, 2021 Can anyone tell me how to import (if possible) sketchup file? When I try to import skp file a warning comes up that says "This skp file was created in an incompatible software version. Unable to import." The object is a 2019 version, but I also tried a download for a 2021 version, and get same message. Have never imported objects before, so not sure what is needed, or limitations for sketchup. TIA Link to comment Share on other sites More sharing options...
Solution solver Posted August 30, 2021 Solution Share Posted August 30, 2021 39 minutes ago, SandraH said: The object is a 2019 version You may need a 2018 version. I'd find one, not necessarily the symbol you need, and try it. Did you search the forum? Probably more specific info in previous similar threads. Link to comment Share on other sites More sharing options...
SandraH Posted August 30, 2021 Author Share Posted August 30, 2021 I wondered if that might be the issue. I will try importing a 2018 item, as there was no older version of the pool table. I only searched pool table in the forum. Thanks for the response. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 30, 2021 Share Posted August 30, 2021 There's a couple of pool tables available in the bonus catalogs. Link to comment Share on other sites More sharing options...
