mdag28 Posted July 27, 2021 Share Posted July 27, 2021 I'm having difficulty dimensioning a cross-section. I can't figure out the proper snap and/or dimension settings to dimension from the bottom of the brown framing to the top of the white column. I've checked my default snap and dimension settings and can't get anything to show this. I want to measure this so I can move the framing up and rest on top of the column. This is from a larger file and is for a porch roof and beam that was drawn manually. In order to raise the porch roof planes and beams, I need this measurement. Thank you Brick_base.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 28, 2021 Share Posted July 28, 2021 DJP Link to comment Share on other sites More sharing options...
solver Posted July 28, 2021 Share Posted July 28, 2021 Link to comment Share on other sites More sharing options...
mdag28 Posted July 28, 2021 Author Share Posted July 28, 2021 Thank you both DJP and Eric. Your responses have helped me a lot and solves my problem. Link to comment Share on other sites More sharing options...
StephenLambert Posted August 2, 2021 Share Posted August 2, 2021 Thx for your answers! It's was helpful!! Link to comment Share on other sites More sharing options...
