Kristine Posted January 22, 2015 Share Posted January 22, 2015 I've tried everything to make a lower cabinet backsplash visible though no matter what boxes I have checked whenever I enter a value in the 'Backsplash Height' field it is automatically discarded and re-set to '0'. I have the cabinet against a wall and the 'Always Present' box ticked. To be honest, I don't even really need the backsplash though just want to know what I'm doing wrong here. Thanks. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 22, 2015 Share Posted January 22, 2015 It could be that the cabinet is a little recessed into the wall (that would make the backsplash appear inside of the wall, making it invisible for all practical purposes). or if all else fails (so it seems it already has) you can manually replace missing backsplash using reshaped, manually placed soffit objects and then apply your backsplash material to them, Soffits are part of "Cabinet Tools" but can often fill in for other types of objects. DJP Link to comment Share on other sites More sharing options...
Kristine Posted January 22, 2015 Author Share Posted January 22, 2015 Sorry to add further to the discussion before there has even been a response, though I just realised I'm also unable to alter the position of handles (height from top). I'm assuming these issues are related to the '(D)' symbol in the dialogue box which I'm pretty sure indicates 'default'? If so, why can't I over-ride it? I edited the cabinet settings in the over-all defaults and it seems I can allocate a specific default though I can't make changes on a per cabinet basis. Is this simply a limitation of the program? Link to comment Share on other sites More sharing options...
CCRRAR2 Posted January 22, 2015 Share Posted January 22, 2015 I discovered you have to be sure to delete the (d) in order to change the values. Have you had any luck trying that? Rob Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2015 Share Posted January 22, 2015 I discovered you have to be sure to delete the (d) in order to change the values. Have you had any luck trying that? Rob Rob is correct , if there is a (D) or a check mark in the default box it MUST be deleted or unchecked to alter the measurement otherwise it just reverts to the default setting. M. Link to comment Share on other sites More sharing options...
Solution Kristine Posted January 22, 2015 Author Solution Share Posted January 22, 2015 Oh, what an idiot. I can't believe I didn't try deleting it. I simply assumed it was fixed. Thank you! Link to comment Share on other sites More sharing options...
Kbird1 Posted January 23, 2015 Share Posted January 23, 2015 don't be too hard on yourself ...you aren't the 1st Link to comment Share on other sites More sharing options...
