AndrewMcDonald Posted January 12, 2021 Share Posted January 12, 2021 When I create a new basement (Build/Floor/Build Foundation) and set wall height to 100" (per the help) I get a basement but it defaults to hardwood floors and a drywall ceiling. If I change the material for the floor to concrete, I get a dialog box the dialog box below. Clicking yes changes the floor but now there's trim at the bottom of the concrete walls. I could go on but what I would like is what the basement would look like with no drywall, no flooring, no trim, nothing. I just want to see an empty basement with concrete walls and floor and the joists from the floor above. I'm a new user (three days!) so I hope this isn't a stupid easy question. I did some searching but I can't find anything that addresses this issue. Link to comment Share on other sites More sharing options...
solver Posted January 12, 2021 Share Posted January 12, 2021 9 minutes ago, AndrewMcDonald said: I just want to see an empty basement with concrete walls and floor and the joists from the floor above. Give it a Room Type of Unfinished. Suite doesn't do framing, so you won't see joists. Link to comment Share on other sites More sharing options...
AndrewMcDonald Posted January 12, 2021 Author Share Posted January 12, 2021 Yup. It was a silly question. Thanks for a not silly answer! Link to comment Share on other sites More sharing options...
cindyw224 Posted January 14, 2021 Share Posted January 14, 2021 I am using Pro 2020 and do not have an option for unfinished as a room type. How can I show that the ceiling is open? Link to comment Share on other sites More sharing options...
dantappin Posted December 29, 2024 Share Posted December 29, 2024 Old thread - tried "unfinished" and the room still has drywall on the walls and ceiling. Link to comment Share on other sites More sharing options...
Rookie65 Posted December 29, 2024 Share Posted December 29, 2024 In the basement level (floor 0)? Or did you check "unspecified?" Link to comment Share on other sites More sharing options...
