KitchenMike Posted January 9, 2021 Share Posted January 9, 2021 I am still having issues with the dishwasher placement. As you can see, in the 3D model, the dishwasher is in the correct position. In the 2D view, i had to move the dishwasher out so that the back of it aligned with the counter edge. If i put the dishwasher in the 2D model correct, below is what happens... I am using Home Designer Pro 2021. Thank you. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 10, 2021 Share Posted January 10, 2021 https://www.homedesignersoftware.com/support/article/KB-00288/message-the-symbol-you-are-trying-to-place-was-designed-to-be-placed-into-the-front-of-a-cabinet.html Link to comment Share on other sites More sharing options...
solver Posted January 10, 2021 Share Posted January 10, 2021 When you edit a post, your edit does not trigger the forum to show something has changed. Either add the info in a new comment, or make a new comment saying that the original post was edited. Link to comment Share on other sites More sharing options...
KitchenMike Posted January 10, 2021 Author Share Posted January 10, 2021 Eric, thanks for the video. I was trying to place it into the drawing in 2d instead of dragging from the library to the cabinet face as you showed. That did work. I was confused because this was not how all the other appliances are placed. As the dishwasher is integrated, this now makes sense to me. Thanks. Link to comment Share on other sites More sharing options...
solver Posted January 10, 2021 Share Posted January 10, 2021 4 minutes ago, KitchenMike said: I was trying to place it into the drawing in 2d That works the same. Select in the library, click on cabinet to place it. Link to comment Share on other sites More sharing options...
