Thundercat Posted December 13, 2020 Share Posted December 13, 2020 A drawing that I have was developed (several years ago) using X6 Premier. On Friday I posted on ChiefTalk Forum if someone could update my X6 drawing to X12, which was done and sent back to me. I purchased and installed Home Designer Professional 2021 yesterday. Although the drawing opens up I cannot make changes. I have spent about 6 hours on the internet. I have checked the locks for the various layers there are a few locks on for the roof. The following "allow for editing" was also checked by the person who sent me the X12 update drawing. Any thoughts and or recommendations? Thanks very much Bruce To allow editing in Home Designer If a Chief Architect user wants to be able to send a Home Designer user a file, first check to make sure that the versions that both users have are compatible. If the versions are compatible, then, the Chief Architect user needs to allow for editing in the Home Designer programs before sending the file. Click Edit> Default Settings , and in the Default Settings dialog, click on Plan, then click the Edit button. In the General Plan Defaults dialog that displays, check the Allow Editing in Select Home Designer Products box. Click OK to accept the change then Done to close the Default Settings dialog. Chief Architect X12 <=> Home Designer 2021 Chief Architect X11 <=> Home Designer 2020 Chief Architect X10 <=> Home Designer 2019 Chief Architect X9 <=> Home Designer 2018 Chief Architect X8 <=> Home Designer 2017 Chief Architect X7 <=> Home Designer 2016 Chief Architect X6 <=> Home Designer 2015 Link to comment Share on other sites More sharing options...
solver Posted December 13, 2020 Share Posted December 13, 2020 28 minutes ago, Thundercat said: The following "allow for editing" was also checked by the person who sent me the X12 update drawing. Any thoughts and or recommendations? How do you know it was checked? I've never seen this not work. Could you attach the plan file and I'll take a look. Link to comment Share on other sites More sharing options...
solver Posted December 13, 2020 Share Posted December 13, 2020 And just a FYI. The plan did not need to be updated to X12, it just needed to be opened and that Allow For Editing flag set. Any version from X6 on could have done it. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 14, 2020 Share Posted December 14, 2020 22 hours ago, solver said: How do you know it was checked? I've never seen this not work. Could you attach the plan file and I'll take a look. I opened the plan and checked it for him as a courtesy. I'm not sure why it's not working either and suggested he contact Tech Support. Here's the plan for whatever it's worth... HD Edit.plan Link to comment Share on other sites More sharing options...
solver Posted December 14, 2020 Share Posted December 14, 2020 1 hour ago, Alaskan_Son said: I opened the plan and checked it for him as a courtesy. I'm not sure why it's not working either and suggested he contact Tech Support. Here's the plan for whatever it's worth... HD Edit.plan I opened the plan you attached in Pro 2021 and was able to make all sorts of changes. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 14, 2020 Share Posted December 14, 2020 The plan opens and edits in my trial version of Pro 2021. I also opened it in X12 and it is properly marked for use in Home Designer titles. Look again. DJP Link to comment Share on other sites More sharing options...
