HHMFOG Posted November 29, 2020 Share Posted November 29, 2020 I cannot figure out how to do this. I could use some help or guidance to figure if the software is capable of allowing for this. This is for a custom, soundproof home theater room. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 29, 2020 Share Posted November 29, 2020 Suite is the least able software that Home Designer makes, it is also the cheapest. That said, it appears that you have figured out how to create a 12" thick wall. Now you just draw two such walls at 45 degrees to each other and place a door in each wall. The main thing you cannot do using Suite is to vary the thickness of doors nor can you alter the casing of such doors in Suite. Other than those limitations that are built-in, you should be able to do this in Suite. DJP Link to comment Share on other sites More sharing options...
solver Posted November 29, 2020 Share Posted November 29, 2020 8 hours ago, HHMFOG said: I could use some help or guidance to figure if the software is capable of allowing for this. It's not. Link to comment Share on other sites More sharing options...
HHMFOG Posted November 29, 2020 Author Share Posted November 29, 2020 11 hours ago, DavidJPotter said: Suite is the least able software that Home Designer makes, it is also the cheapest. That said, it appears that you have figured out how to create a 12" thick wall. Now you just draw two such walls at 45 degrees to each other and place a door in each wall. The main thing you cannot do using Suite is to vary the thickness of doors nor can you alter the casing of such doors in Suite. Other than those limitations that are built-in, you should be able to do this in Suite. DJP Thank you for replying David. Would the Architectural version better allow me to create the plan I am attempting? And if so is there some guidance that would help get me started or specific videos or tutorials that would help on this particular topic? Thank you in advance for your assistance. Link to comment Share on other sites More sharing options...
solver Posted November 29, 2020 Share Posted November 29, 2020 I think David may not have understood the problem. I've tried to show what I think you want with a darker gray door in a wall shown in the closed position, and the lighter gray shown open. If so, no Home Designer or Chief Architect product will do this using the included door and wall tools. With some work, you could model this, but it won't function as a door. Link to comment Share on other sites More sharing options...
HHMFOG Posted November 30, 2020 Author Share Posted November 30, 2020 Thank you Solver. This works as this is what I am trying to accomplish. Assumed Suites woudn't do this. Found some other things it wouldn't do and decided to upgrade to Architectural version. Not sure if I'd need more to replicate what you've done but hoping I can manage it with what I've got so far. Link to comment Share on other sites More sharing options...
