window label location
odesign
In plan view in one of my Home Designer Pro 2021 drawing files my window labels are located in the window opening as opposed to outside of the window as they do in all my other drawing files. I feel like this should be an obvious setting but I can’t find it. Where should I be looking?
Thanks for help on this.
Tom Oakley
If you aren't going to change the window size, you can open the label and put a couple of "enter" taps in before it and it will move below the window if that helps. If you change the size, the label won't change, so be careful if you use this.
