ACorn12 Posted August 20, 2020 Share Posted August 20, 2020 Our terrain is rectangular but not flat. At the front, on the street side, we call this level 0 at height 0cm Where the house stands it's a flat terrain that's a bit higher then the street. About 40cm higher. So from the street side it goes up to the front door, about 40cm higher than the street. At the back, about 4 meters from the back of the house, the terrain starts to lower. About 8 meters from the back of the house (level is about -80cm there) is the lowest point and it's flat all the way to the end of the terrain from there. So I added these elevation lines: At the front of the terrain: elevation 0mm (0cm) At the front door: elevation: 400mm (40cm) At the back of the house: 400mm (40cm) 4m from the back of the house: 400mm (40cm) 8m from the back of the house: -80mm (-80cm) At the back of the terrain: -80mm (-80cm). But that clearly doesn't do the job so I'm probably not understanding it correctly. Can anyone help me understand how to draw this terrain in home designer? Thanks! Link to comment Share on other sites More sharing options...
solver Posted August 20, 2020 Share Posted August 20, 2020 A couple of pictures will help others help you. Check out the links above for terrain how to info. Link to comment Share on other sites More sharing options...
ACorn12 Posted August 20, 2020 Author Share Posted August 20, 2020 Ok. So I'm using Home Designer PRO 2021. (I'm new. Just started using/experimenting today). The terrain I want to draw looks like the attached picture. Left is the street level (0cm). It goes up to where the house is. At the back of the house it goes to a level lower than the street. The terrain is flat where the house stands. And the backyard is flat too. Just these two curves I can't get it done Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 20, 2020 Share Posted August 20, 2020 Are you sure you entered the elevations correctly? -80mm and -80cm are not the same thing. Link to comment Share on other sites More sharing options...
ACorn12 Posted August 21, 2020 Author Share Posted August 21, 2020 I created a new document and went to Terrain -> Create Terrain Perimeter. It draws a terrain of 15x30m by default. For testing, I kept this size. I added elevation lines like show in this picture: As you can see I set elevation at 0mm at the bottom. Then two elevation lines of 400mm (where the house sits). And as a test two elevation lines of -400mm for the backyard. I expected it to draw a terrain like described above but instead got something totally different. This is what I get: Link to comment Share on other sites More sharing options...
DIG5050 Posted August 21, 2020 Share Posted August 21, 2020 The program will try to "smooth" between the lines to simulate soil condition typical after grading. It's similar to fitting a curve to data points on a graph. To get the terrain to look like what Jo_Ann drew above, use terrain regions. Link to comment Share on other sites More sharing options...
