millr0955 Posted June 7, 2020 Share Posted June 7, 2020 I'm using Home Designer Pro 2021. Adding a bath and utility room in all metal building. The shower requires additional framing based on the install manual. Most of this can be accommodated by moving existing studs to match. But I end up one stud short. I can't figure out how to add a stud. Link to comment Share on other sites More sharing options...
solver Posted June 7, 2020 Share Posted June 7, 2020 On 6/7/2020 at 4:23 PM, millr0955 said: I can't figure out how to add a stud. Expand Copy/Paste Link to comment Share on other sites More sharing options...
millr0955 Posted June 7, 2020 Author Share Posted June 7, 2020 copy/paste returns this error message: Link to comment Share on other sites More sharing options...
solver Posted June 7, 2020 Share Posted June 7, 2020 On 6/7/2020 at 4:30 PM, millr0955 said: copy/paste returns this error message: Expand What are you doing that is resulting in that message? What type of view etc. Watch on YouTube: http://youtu.be/gOPq6ZYqzzM?hd=1 Link to comment Share on other sites More sharing options...
barthmv Posted June 7, 2020 Share Posted June 7, 2020 you can easily add an additional stud by copying a stud and then grab it and move it into place. Transform/replicate (copy) works well also and just move the copy. The copy paste function does seem to give the error described above Link to comment Share on other sites More sharing options...
barthmv Posted June 7, 2020 Share Posted June 7, 2020 forgot to mention that auto framing needs to be disabled before adding the stud Link to comment Share on other sites More sharing options...
