EStier Posted May 23, 2020 Share Posted May 23, 2020 I am a builder that does additions to existing houses. We primarily build with masonry construction. Many of my projects have lanais that are also built out of masonry. I could use some help on how to do a few things. 1. How can i make my posts show up on my floor plan. Sometimes we fill in between the columns and I would like to show where the new and existing are. I use railings to create the space and the columns can be 8x8, 8x16, 12x12 or 16x16. 2. Is it possible to create a masonry column in HDP? 3. In the railings dialogue I can change the size of the newel to look like a masonry column. However the beam above is still a 2-2x12 beam. ours are typically 8x16 and sit directly on top of the column. I put my most recent plan file in this post. Remember - I am a builder and hand these off to my draftsman. I am not worried about small flaws. It is good enough for my clients to figure out. Roarty 2.0 Test.plan Link to comment Share on other sites More sharing options...
Rookie65 Posted May 23, 2020 Share Posted May 23, 2020 One of the new features in HDP 2021 is that the posts do show up in railings on the floor plans. You can also adjust the size of your beams in the railings. Link to comment Share on other sites More sharing options...
solver Posted May 23, 2020 Share Posted May 23, 2020 I don't have Pro 2019, so this is Pro 2020. You can vary the width of the beam by changing the thickness of the wall. Don't know of a way to change the height of the beam. You could draw these things manually with the slab tool and they would look correct. Use a Room Divider to form the room. Showing a 16" column and with a 16" thick wall. Link to comment Share on other sites More sharing options...
Rookie65 Posted May 23, 2020 Share Posted May 23, 2020 You can change the beam widths and heights in HDP 2021 Link to comment Share on other sites More sharing options...
EStier Posted May 23, 2020 Author Share Posted May 23, 2020 Well you convinced me to upgrade. Especially because I can use 24x36 paper too. Thanks Link to comment Share on other sites More sharing options...
Rookie65 Posted May 23, 2020 Share Posted May 23, 2020 You will find a lot of features that have been upgraded. Enjoy! Link to comment Share on other sites More sharing options...
EStier Posted May 25, 2020 Author Share Posted May 25, 2020 On 5/23/2020 at 3:38 PM, Rookie65 said: You can change the beam widths and heights in HDP 2021 Expand Where do you see that? I looked all through the railing specification and don't see anything. Link to comment Share on other sites More sharing options...
solver Posted May 25, 2020 Share Posted May 25, 2020 On 5/25/2020 at 3:18 PM, EStier said: Where do you see that? I looked all through the railing specification and don't see anything. Expand Look at the Rails panel. Link to comment Share on other sites More sharing options...
EStier Posted May 25, 2020 Author Share Posted May 25, 2020 On 5/23/2020 at 3:14 PM, Rookie65 said: One of the new features in HDP 2021 is that the posts do show up in railings on the floor plans. You can also adjust the size of your beams in the railings. Expand On 5/25/2020 at 3:21 PM, solver said: Look at the Rails panel. Expand Found it, thanks Link to comment Share on other sites More sharing options...
