Breeze91 Posted April 21, 2020 Share Posted April 21, 2020 Good day, There is probably a quick solution to this, so hopefully one could point me to it. I looked through all the ramp settings to no avail. Attached is an image of my ramp which is floating above the grade. What steps would be necessary to make it connect from the porch to the terrain? Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 21, 2020 Share Posted April 21, 2020 Select and then open the dialog box of the ramp and lower it bottom until it meets the surface of the terrain or raise the terrain using its dialog box to meet the ramp. Either method should work, it is just a matter of which method fits your situation. Open those dialog's and really see what is there and what it empowers you to do. DJP Link to comment Share on other sites More sharing options...
Breeze91 Posted April 21, 2020 Author Share Posted April 21, 2020 Thanks to both. David, I will play around with the height of the ramp. So there's no way to snap the ramp to the terrain, essentially. Eric, I have added the signature. thanks! Link to comment Share on other sites More sharing options...
solver Posted April 21, 2020 Share Posted April 21, 2020 4 minutes ago, Breeze91 said: So there's no way to snap the ramp to the terrain, essentially. Ramps are typically low slope for a reason, so keep that in mind. Ramps, and stairs may also be drawn from the top down using the right mouse button (on a PC). Link to comment Share on other sites More sharing options...
