Asa_West Posted April 5, 2020 Share Posted April 5, 2020 Hello, Please refer to the image below as well as the two attached plans. I am trying to design an addition onto our existing house. The new addition will be a single addition on the back of the house, shown inside the rounded square highlight. Our second floor is inside the roof, like a cape cod cottage style house. I have attached the model of the base house with our actual roof line. I have also attached the model with the addition drawn and the roof error as a result of trying to auto create the roof. The roof in the addition is how I would like it too look, however I can't figure out how to work the two roofs independently in the roof builder. Any help would be very much appreciated. Thanks, Asa West House Addition - Roof Error.plan West House Addition R0.plan Link to comment Share on other sites More sharing options...
solver Posted April 5, 2020 Share Posted April 5, 2020 Link to comment Share on other sites More sharing options...
Asa_West Posted April 5, 2020 Author Share Posted April 5, 2020 These are the choices I see. Link to comment Share on other sites More sharing options...
solver Posted April 5, 2020 Share Posted April 5, 2020 Oops -- thought I was looking at Suite. I see you have Ignore Top Floor checked. Is that the only way you could get the roof to build? If you uncheck that, the addition roof builds, but the original roof changes. Link to comment Share on other sites More sharing options...
Asa_West Posted April 5, 2020 Author Share Posted April 5, 2020 That was the only way I could get the roof to build at the 1st floor level, instead of a full second story. I was consulting this tutorial: https://www.homedesignersoftware.com/support/article/KB-00358/automatically-building-a-one-and-a-half-story-roof.html Link to comment Share on other sites More sharing options...
solver Posted April 5, 2020 Share Posted April 5, 2020 Watch on YouTube: http://youtu.be/XXfg6u2K2o4?hd=1 Link to comment Share on other sites More sharing options...
Asa_West Posted April 5, 2020 Author Share Posted April 5, 2020 Hi Eric, This is great, thanks! Once I get the roof like I want utilizing the false walls on the second floor, I can uncheck the auto update roof and delete them...right? Link to comment Share on other sites More sharing options...
solver Posted April 5, 2020 Share Posted April 5, 2020 9 minutes ago, Asa_West said: can uncheck the auto update roof and delete them...right? Correct Link to comment Share on other sites More sharing options...
LawB10 Posted April 7, 2020 Share Posted April 7, 2020 Make sure you uncheck "Ignore the second floor" and build the second floor the same as the first floor minus the addition. Uncheck upper pitch on the back wall on the first and second floor. Gable the side and middle wall (s) on the first and second floor. On the second floor @ the middle wall, draw a wall that makes two rooms, then a wall that creates a front and back room, make both front rooms attic, move the wall and lower the back rooms until they line up. You should have a Salt box roof. Set the pitch on the back wall and front main walls. Uncheck auto rebuild roofs and reset to the default ceiling height. Link to comment Share on other sites More sharing options...
mmills Posted April 12, 2020 Share Posted April 12, 2020 You guys are awesome and quick. I will try to digest some of this info and see if I can get it right. Thanks so much for your willingness to help a rookie. HAPPY EASTER Link to comment Share on other sites More sharing options...
