evanacree Posted February 19, 2020 Share Posted February 19, 2020 I am trying to fix the roof line of the attached video (Roof Line.mov). You can see the middle section is not aligned with the others. My goal is to have the two left roof planes on the same level. You can somewhat see the goal roof lines in the attached image. The left two are aligned and the right (excluding the roof with the dormers) is on its own. I am currently using Suite. Is this only possible to edit with Pro? Roof_Line.mov Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 19, 2020 Share Posted February 19, 2020 DJP 2 Link to comment Share on other sites More sharing options...
evanacree Posted February 19, 2020 Author Share Posted February 19, 2020 Should've come here for help a lot sooner! Thank you so much, sir Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 19, 2020 Share Posted February 19, 2020 It has nothing to do with the pitch of the roof. Extend the left wall across as shown. In the new "room" that is highlighted, start lowering the ceiling until the roof blends with the roof on the left. 1 Link to comment Share on other sites More sharing options...
evanacree Posted February 21, 2020 Author Share Posted February 21, 2020 Thank you for the response, @Jo_Ann and my apologies for the delay. I attempted what you said but didn't quite work. Can you clarify which wall in the attached screenshot? Link to comment Share on other sites More sharing options...
