homedesignKonan Posted February 2, 2020 Share Posted February 2, 2020 I" working on a custom shower and and pan. I'm also including a bench. I can seem to remove moldings from this single wall w/o removing it from the whole room. Any help would be great Link to comment Share on other sites More sharing options...
Rookie65 Posted February 2, 2020 Share Posted February 2, 2020 Make the shower its own room w/a room divider. Then open the room it's in and delete the mouldings. Also VERY helpful to everyone to create/update a signature so people always know which program and version you are using. You will also find the reference manual a great resource so you don't have to wait for a reply from others. Link to comment Share on other sites More sharing options...
solver Posted February 2, 2020 Share Posted February 2, 2020 Link to comment Share on other sites More sharing options...
homedesignKonan Posted February 2, 2020 Author Share Posted February 2, 2020 Thanks for the responses. The issue isn't the inside of the shower but the outside of the curb in the room. I have a 3 1/2" curb and 7 1/2" base. the curb wont have base but tile and I cant figure out how to remove it from this one wall. Is it doable? Also, I will add and update my signature to include the version i'm working with. Link to comment Share on other sites More sharing options...
solver Posted February 3, 2020 Share Posted February 3, 2020 1 hour ago, homedesignKonan said: Is it doable? Did you see my response above? Link to comment Share on other sites More sharing options...
homedesignKonan Posted February 3, 2020 Author Share Posted February 3, 2020 Yes Eric, but when i use this method it removes all molding from the entire room. my problem is isolating one individual wall. It doesn't seem to do this when I click on a wall. Link to comment Share on other sites More sharing options...
solver Posted February 3, 2020 Share Posted February 3, 2020 9 minutes ago, homedesignKonan said: my problem is isolating one individual wall. Watch on YouTube: http://youtu.be/BmHtqWnKFGM?hd=1 1 Link to comment Share on other sites More sharing options...
homedesignKonan Posted February 3, 2020 Author Share Posted February 3, 2020 Thanks Eric. For some reason when I double clicked on the wall it opened "Room Specifications" instead of "Wall Specifications". I clicked on the wall in 2D and it gave me what I needed. Thanks again. Link to comment Share on other sites More sharing options...
solver Posted February 3, 2020 Share Posted February 3, 2020 Selecting Walls Like other objects, walls can be selected in a variety of ways. See Selecting Objects. • In plan view, if wall hatching has been applied to a wall using the Hatch Wall tool, the hatching may be selected first. Click Select Next Object to select the wall itself. See Hatch Wall. • When Select Room Before Wall in 3D is checked in the Preferences dialog and you click on a wall in a cross section/elevation or camera view, the room defined by that side of the wall will become selected instead of the wall. See Appearance Panel and Selecting Rooms. Link to comment Share on other sites More sharing options...
homedesignKonan Posted February 3, 2020 Author Share Posted February 3, 2020 Great! Thanks once again. Link to comment Share on other sites More sharing options...
