PEGDesign Posted December 3, 2019 Share Posted December 3, 2019 I've just downloaded Home Designer Pro and hope someone can identify what tools and steps I should use to create a porch that is under a gable roof. I've attached an image of what I'm trying to build. Any thoughts or ideas will be helpful. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 3, 2019 Share Posted December 3, 2019 1. Draw the walls using the appropriate wall types that matches you home 2.Verify the exterior dimensions around the footprint of your home. (Innaccurate dimensions equals a worthless outcome) 3. Measure the ceiling height of the majority of your home's rooms and enter that value into "Edit - Default Settings - Floors and Rooms - First Floor - Finished Ceiling Height" (this value locates the "Baseline Height" of your roof planes once built) 4. Calculate the pitch (angle) of your roof planes and then add that value into your "Build Roof Dialog right BEFORE actually ordering your roof system built. 5. You "Tell" or input into your software walls each wall that is to be designated a "Gable Wall" (If you do not understand what that term means "Google It" or study what roof terms mean in the "Build Roof Dialog - Roof Types tab" . 6. Once you have done these things correctly, then and only then, order your roof system be created folloing your correct orders. You get what you input into the software to guide it to a result, if you are not getting the desired result it is YOU who have erred. The software is a mechanical device that requires you competence gained by your study, your practice, failures and successes. It does basically nothing on its own. DJP Link to comment Share on other sites More sharing options...
LawB10 Posted December 4, 2019 Share Posted December 4, 2019 Here you go..... Untitled .plan Link to comment Share on other sites More sharing options...
