TwilaMurdoch Posted November 15, 2019 Share Posted November 15, 2019 Is there a way to import a pdf floorplan file rather than recreating it Link to comment Share on other sites More sharing options...
LawB10 Posted November 15, 2019 Share Posted November 15, 2019 Click File>Import a drop down list will appear... Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 15, 2019 Share Posted November 15, 2019 You, as LawB10 said use "File - Import PDF" and then import your target PDF file, then once in your plan vew of the plan file, you then scale it using the provided scaling tool and dimension tools to verify its proper scaling and then you can trace over it to quickly layout walls, doors and windows indicated in the PDF file using your 3D tools for walls, windows and doors. You use dimension tools on the walls to obtain accuracy. DJP Link to comment Share on other sites More sharing options...
