kevincam Posted August 29, 2019 Share Posted August 29, 2019 I'm stuck on this one. I've put items on a wall, speakers, TV, amplifier, etc. and now I'm trying to find a way to get a view that I can see the dimensions of where things are in relation to the floor. The placement. I tried elevation view but it only shows somethings and I still don't know how to get the dimensions to appear. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 You will have to manually dimension them to see. Each item should have their own dialog box where you can set the distance from floor or ceiling, depending on the item. Link to comment Share on other sites More sharing options...
kevincam Posted August 29, 2019 Author Share Posted August 29, 2019 They are where I want them. What I would like is something that shows me the dimensions that I set them at and not have to go back and figure out the positioning that I did since I was doing it all in real time and didn't document where I positioned them since I thought there would be a way to get HDP to show me. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 try a string of manual dimensions vertically at each object in elevation view. Or you may be able to now click on each item and see the description box and the dimensions should show up there Link to comment Share on other sites More sharing options...
kevincam Posted August 29, 2019 Author Share Posted August 29, 2019 Look at my screenshots. They don't appear in Elevation view. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 you have to enter them yourself. they do not show on their own Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 and for what you don't see in elevation view, make sure those particular items are "visible" for that camera view. Remember, every camera has their own choices for what you can and can't see Link to comment Share on other sites More sharing options...
kevincam Posted August 29, 2019 Author Share Posted August 29, 2019 Ok, I don't know how to make them visible in the camera view. What setting is it that controls that. I selected the camera in plan view and opened it but I don't see anything there. Would it be some where else? Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 when you are using the camera you want, go to the "display options" box (the white one w/a red check mark in it). Then find the item group you are trying to show and see if that is checked or not. If it isn't, check it and it should show. Or take a look through your reference manual and see if that helps you as well. Link to comment Share on other sites More sharing options...
kevincam Posted August 29, 2019 Author Share Posted August 29, 2019 Keith, Yeah, that doesn't work so maybe it's just not possible to show these items in elevation view. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 If you can put it on the plan, you can see it in elevations. Open the item in plan view and see what category it's in, then make sure it's checked to display. Link to comment Share on other sites More sharing options...
kevincam Posted August 29, 2019 Author Share Posted August 29, 2019 Yes, I did that and it's checked to display must be something I'm not doing. I've attached the plan file maybe that will make it faster to figure out what's wrong. Sitio Gravata 1 - Final.plan Link to comment Share on other sites More sharing options...
solver Posted August 29, 2019 Share Posted August 29, 2019 Link to comment Share on other sites More sharing options...
kevincam Posted August 29, 2019 Author Share Posted August 29, 2019 Ok, I figured it out. I had to actually be looking at the camera view when I open the display settings. I was looking at the plan view. Thanks. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 29, 2019 Share Posted August 29, 2019 Turn on "interior furniture" in the elevation view. 1 Link to comment Share on other sites More sharing options...
solver Posted August 29, 2019 Share Posted August 29, 2019 Your plan. 1 Link to comment Share on other sites More sharing options...
