Fredo649 Posted May 9, 2019 Share Posted May 9, 2019 I am trying to wrap a roof return all the way around a garage to break up a tall 2 story wall from a gable wall which worked fine to an eave wall which is not working . It doesn't want to work. AL_DEJONG_REVISED_May_8TH..plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 9, 2019 Share Posted May 9, 2019 HTH DJP Link to comment Share on other sites More sharing options...
Fredo649 Posted May 9, 2019 Author Share Posted May 9, 2019 Yes I know about the different pitches and I will try to clean them up , The customer wants the ridges to match which of course because of the different widths of the home it changes the pitch. Thanks for your help. Link to comment Share on other sites More sharing options...
Rookie65 Posted May 9, 2019 Share Posted May 9, 2019 Fredo, If he only wants the ridges to align, and not the fascias, then you can manually draw the roofs..Set the ridge to the desired height and use the same pitch for each roof if desired. If they need specific ceiling heights per room then of course that will probably not be a good solution. Though you can lock ridges and fascias and let the pitch be what it is between those 2 items. Was just a thought. Link to comment Share on other sites More sharing options...
