uploading building plans
dursulan
Commonly you import the PDF, then check the correctness of its scaling using Home Designer dimension tools. When properly checked for correctness then you can trace over the indicated walls which does save time. It is easier to do in Chief Premier but is commonly done as above in Home Designer software that allows the importation of PDF files.
