MississippiMims Posted April 18, 2019 Share Posted April 18, 2019 I'm creating a 24" x 36" layout and when I changed the paper size the graphics did not change with it. I have already resized the graphics to match the paper size and would now like to save that as a template to have the next time I need to use this paper size. I searched the Knowledge Base and found a tutorial that said to go to File - Templates - something. I'm using Home Designer Pro '19 and there is no "template" option under the file tab. Any suggestions? Link to comment Share on other sites More sharing options...
solver Posted April 18, 2019 Share Posted April 18, 2019 18 minutes ago, MississippiMims said: I searched the Knowledge Base and found a tutorial that said to go to File - Templates - something. I'm using Home Designer Pro '19 and there is no "template" option under the file tab. Make sure you are searching the Home Designer KB and not the one for Chief Architect. 22 minutes ago, MississippiMims said: now like to save that as a template to have the next time I need to use this paper size. Profile.layout is the default layout file. You can save anywhere (I think), but I'd save in the default directory. Open file -- change to Layout and select the one you want. Link to comment Share on other sites More sharing options...
MississippiMims Posted April 18, 2019 Author Share Posted April 18, 2019 So this is basically saving a blank copy of the layout and then opening that blank copy when I need that paper size? Link to comment Share on other sites More sharing options...
solver Posted April 18, 2019 Share Posted April 18, 2019 That's it. It looks like with Pro, after you open the Layout, you will need to do a Save As, giving it the plan name and placing it in the same directory as the plan. Otherwise you will overwrite the layout. Link to comment Share on other sites More sharing options...
MississippiMims Posted April 18, 2019 Author Share Posted April 18, 2019 Ok. Thank you. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 18, 2019 Share Posted April 18, 2019 With Pro, the largest sheet it can save in a layout is 18"x24". What I do in that case if the plan is too big for 18x24 paper is send it to layout on 11x17 paper in 1/8" scale. Yet I will have my title block say "1/4"=1'-0" as the scale. When I send it to be printed, I have them double the print size and have it printed on 24x36 paper. DO NOT let them "fit to page" or it will mess up the scaling. This way you have a 22 x 34 correctly scaled drawing on 24x36 paper. Hope this helps? Link to comment Share on other sites More sharing options...
MississippiMims Posted April 23, 2019 Author Share Posted April 23, 2019 Actually just tried to save a PDF of my layouts in this size to send to my printer and noticed this problem. Does this mean that I wasted my time setting up a 24x36 layout sheet and now must set up an 11x17 sheet? Thank you for the heads up. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 23, 2019 Share Posted April 23, 2019 It wasn't a total waste of time if something was learned from it. The only "template" I keep is a master plan saved with the defaults I like (font, door style, window sizes, siding, dimensions, etc.) so I don't have to reset them for every project. Then I save each new project with its own name and then change any particular defaults needed for that project only. That's why I feel bad when I see people post about saving a template of a particular house style, then realizing they want to change it after. We all have our own styles and depending on if you're using the program for business, or a weekend warrior, we all find what works best for us. Link to comment Share on other sites More sharing options...
