French or Double Doors
beynec
Not 100% sure on Architectural, though you should be able to go to the "default settings>doors>interior doors>options" and change the default from "determine by size" to "double doors only" if you are looking for a double door appearance.
You want all doors 36" or less to be double?
You can change the default as Rookie said, and all doors will be double.
You could create a door configured as you like, then add it to the Library for reuse.
