roof over door
Muttley000
34 minutes ago, Muttley000 said:
I just want it to fasten to the wall with brackets
The brackets have nothing to do with the roof -- they are added afterwards.
With Pro, you can manually draw the roof, or you can use invisible walls to create a room, which can have a roof. That room might be called a Porch, or even a Deck, and have a floor.
Click on Door and you should see on the lower left (gable over door or window) click on that input pitch etc. and that should put a roof over your door . You can add the brackets after from the library.
Hope this helps a little.
